Stereo losing power?
jcborden
Having just picked up my LCR my first job was to lose the horrible stereo that someone had previously fitted. I put in my Pioneer unit taken from my previous car and it worked just fine.
However, this morning when I started the car the stereo had lost all the programmed stations and the time. Does anyone have any suggestions as to what would cause this?
thanks,
James
swilky23
230
rochdale
I would guess there is possibly a wire that would go straight to the battery for it to keep its memory when the ignition is off
jcborden
I wondered about that, but have just hooked up the standard connectors so didn't think I needed to do anything else. Certainly on my old car it just used the standard connectors.
Aug 24, 2007
800
swap the permanent live and the switched live wire, yellow and red I think.
dmmsta
Sold car - bought bike
Feb 10, 2007
787
Maidstone - Kent
2nd'd
For some reason the loom on the VW's is differnet from most others, and has the perm-live and switch-live the other way round.
Most aftermarket HU's have a look that you can just unplug these 2 wires (red & yellow as per mylo) so you don't have to cut anything.
jcborden
Thanks guys, that was extremely easy - now all working fine!
