Steering Wheel Buttons and Bug
Mar 18, 2022
Hi everyone :) I had experienced various errors in my Cupra Leon (2023-1.5 eTSI) vehicle before, but this error surprised me a lot :)
To summarize, for a long time, the button group on the right of the steering wheel sometimes worked and sometimes did not. (Button group: menu change button, gear + button, song forward/backward button etc.) Today I discovered that when I turn on the headlights of the vehicle, the buttons do not work. When I turn off the headlights, they work :) In auto mode, if it is evening, the buttons do not work because the headlights are turned on, but during the day when the headlights are off, the buttons work. (Bonus video attached)
Has anyone experienced this problem? I would be very happy if you could provide information.
cairus
135
64
Is there an auto scan? Is everything OEM? The vehicle should still have a warranty? What happens if the light switch is connected to the keypad? If you unplug the light switch, the vehicle goes into an "emergency function" and the light is switched on.
Mar 18, 2022
Everything is oem, i did not change any kind of piece on my car. The car is still under warranty, Now comes the funniest part. The service issue was examined 4 times and the keypad was replaced as a solution. Of course, there was no solution. I found the source of the problem by chance. I will share it with the authorized service, let's see what they say.
cairus
135
64
Test my idea if you want. Unplug the light switch and see if it works. An error message will surely appear and MFA will report
