Hi All
I am having issue with steering since buying car 2013 Ibiza dsg 1.2 tsi i didn't notice it much at first but its more annoying than anything
I purchased a vag com from ebay with full access 17.1.0 it's obviously not original but it allows me scan car with results as below
My issue is when i try to perform steering angle sensor zero step it asks for a security access code and have no idea of what it might be I have tried 40168 as suggested elsewhere online but no joy and it locks you out from re-trying for 10 minutes.
Does anyone else here have 17.1.0 vcds or have any experience of what security access code i should be trying when trying the steering angle sensor calibration.
I know sensor needs calibrating as when driving on a perfect straight flat road the steering wheel is sloped down to left hand side a little as it is driving in a straight line and if i try and centre steering wheel the car moves to the right on the road, remember this has been tested on a completely flat road little to no camber
Tracking has been done 2 times before by reputable garage both having laser 4 wheel alignment with one having a 3D system obviously none of those "experts" have reset the steering angle sensor
It's as if the steering has forgot where it's centre point is
Friday,31,March,2017,13:50:16:53651
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 17.1.0.0
Data version: 20170106 DS267.0
VIN: VSSZZZ6JZDR184756 License Plate: 131C7212
Mileage: 81140km-50418mi Repair Order:
Chassis Type: 6J (6N0)
Scan: 04 08 09 15 17 19 25 32 44 4B 56 0B
VIN: VSSZZZ6JZDR184756 Mileage: 81140km-50418miles
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
32-Differential Locks -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
4B-Multifunc. Module -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
Address 04: Steering Angle (G085) Labels: 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 30031304651122
Coding: 01
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_LWSKLOVW25X 005001
ROD: EV_LWSKLOVW25X.rod
VCID: 7EF398DDE126E6B1BD-802A
1 Fault Found:
1140738 - Steering angle sensor
B1168 54 [009] - Missing Calibration / Basic Setting
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 47
Mileage: 50375 km
Date: 2015.07.15
Time: 09:30:02
Voltage terminal 15: 12.00 V
Voltage terminal 30: 12.15 V
Terminal 15 status: On
Address 08: Auto HVAC Labels: 6J0-820-045.clb
Part No SW: 6J0 820 045 A HW: 6J0 820 045 A
Component: J301 Klimaanlage 0330
Revision: 00 26 08 Serial number: 0000002636958-
Shop #: WSC 00049 770 00144
VCID: 24478AB5E70A6C618B-8070
No fault code found.
Address 09: Cent. Elect. (J519) Labels: 7H0-937-08x-09.clb
Part No SW: 7H0 937 090 B HW: 7H0 937 090
Component: BCM PQ25 Max4 H74 0712
Revision: B9074001 Serial number: 0571 249130950
Coding: 7C882BE88861010001200EF06FCB9EC80FC063A9608C2049200000020000
Shop #: WSC 15338 000 1048576
VCID: 2D516F9174C0AD2954-8078
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 130313 05 54 0403
Coding: 02242D
Subsystem 2 - Part No SW: 6R0 959 802 AP HW: 6R0 959 802 AP Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 007 5110
Serial number: --------------------
Coding: 030000
Subsystem 3 - Part No SW: 6R0 959 801 AM HW: 6R0 959 801 AM
Component: J387__TSG_BT 007 5110
Coding: 020000
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 6R0 959 655 K HW: 6R0 959 655 K
Component: VW10AirbagA0E H10 0020
Revision: -------- Serial number: 003GX01MYKJJ
Coding: 003045
Shop #: WSC 00049 770 00112
ASAM Dataset: EV_AirbaVW10BPAVW250 A01001
ROD: EV_AirbaVW10BPAVW250_VW31.rod
VCID: 4A9B040DED6E9A1151-801E
Crash sensor for side airbag: driver side:
Serial number: 3495RRB400I50G4G7HRS
Crash sensor for side airbag: front passenger side:
Serial number: 3505RRB401A50GBOLON2
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 6J0 920 805 K HW: 6J0 920 805 K
Component: KOMBI H04 0606
Serial number: 00000000000000
Coding: 110A00
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04716
ROD: EV_Kombi_UDS_VDD_RM09_SK46.rod
VCID: 336579E99AE4FBD902-8066
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 090
Component: GW-K-CAN TP20 H74 0712
Revision: B9074001
Coding: 022300
VCID: 70EFB6E5A37280C13F-8024
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H04 0606
Serial number:
Coding: 000000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03709
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
VCID: 6ADBA48D8DAE7A1171-803E
Address 32: Differential Locks
Cannot be reached
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6R0 423 156 C
Component: LenkhilfeTRW V278
Coding: 10111
Shop #: WSC 00788
VCID: 306F76E5F7F2C0C17F-8064
Address 4B: Multifunc. Module Labels: 6J0-959-441.clb
Part No: 6J0 959 441 A
Component: MF-Modul 0007 0001
Coding: 0000002
Shop #: WSC 77005 000 00000
VCID: 316973E1A8F8C9C970-8064
1 Fault Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent - MIL ON
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 6J0 035 156 HW: 6J0 035 156
Component: Radio H05 0012
Revision: R0000000 Serial number: SEZAZ1N6201018
Coding: 010004080203
VCID: 64C7CAB5678A2C614B-8030
End-------------------------(Elapsed Time: 03:15)--------------------------
Coding: 01
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 47
Mileage: 50375 km
Date: 2015.07.15
Time: 09:30:02
Coding: 02242D
Coding: 030000
Coding: 020000
Coding: 003045
Coding: 110A00
Revision: B9074001
Coding: 022300
Serial number:
Coding: 000000
Cannot be reached
Coding: 10111
Shop #: WSC 00788
Coding: 0000002
1 Fault Found:
