Hello , I've got a 54 reg Altea 1.9tdi and Im struggling to reset the steering assist and perform the steering limit stop adaption using vcds.
I have tried turning the steering one turn to the right, then one to the left, driving a short distance , then I'm going into the steering assist basic settings group 060 to activate the basic settings ( the "Go" button is greyed out but I can enable basic settings by the off/on next button).. When I enable it ,it comes up with ok in field one .When I try to check measuring block group 007 it comes up red and doesn't let me in to see the value which is supposed to read between -1.5 and +1.5 degrees. I then tried the steering limit adaption and no joy its as bad as it was before.
I've posted the VCDS Scan below
If anyone could point me in the right direction of where I'm going wrong I would be greatly appreciated as its doing my head in .
Chassis Type: 5P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56
VIN: VSSZZZ5PZ5R013001 Mileage: 200740km-124734miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 016 DH HW: 028 101 186 4
Component: R4 1,9L EDC 0000SG 6093
Revision: 12345678 Serial number: SEZ7Z0D2594380
Coding: 0050071
Shop #: WSC 06401 785 00200
VCID: 6CD7A2954F5A642103-8038
2 Faults Found:
17058 - Cylinder 4 Glow Plug Circuit (Q13)
P0674 - 000 - Electrical Fault - Intermittent
Freeze Frame:
RPM: 1071 /min
Torque: 40.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.48 V
Bin. Bits: 11000100
Temperature: 9.0°C
Bin. Bits: 10110000
17056 - Cylinder 2 Glow Plug Circuit (Q11)
P0672 - 000 - Electrical Fault - Intermittent
Freeze Frame:
RPM: 882 /min
Torque: 46.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.36 V
Bin. Bits: 11000100
Temperature: 9.0°C
Bin. Bits: 10110000
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 N
Component: ASR FRONT MK70 0103
Coding: 0017025
Shop #: WSC 06402 785 00200
VCID: 3D715FD164A03DA9E4-8068
No fault code found.
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No: 5P0 820 047 H
Component: Climatic PQ35 007 0201
Shop #: WSC 00000 000 00000
VCID: 326B7CEDADFEF2D109-8066
Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
Part No SW: 1K0 937 049 K HW: 1K0 937 049 K*
Component: Bordnetz-SG 1.0 H29 0701
Revision: 00029000 Serial number: 00000001173460
Coding: 00880F2700041000001E00000000000000
VCID: 377D4DF9469C17F93E-8062
Subsystem 1 - Part No: 5P0 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer SE359 012 0401
Coding: 00056272
Shop #: WSC 00000
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 D HW: 1K0 909 605 D
Component: S5 AIRBAG VW8 022 0600
Revision: 05022000 Serial number: 0033JD0F34Y8
Coding: 0021301
VCID: 2D516F91B4C0AD2954-8078
Subsystem 1 - Serial number: 6332MSME28196303
Subsystem 2 - Serial number: 6342MSME25254803
Subsystem 3 - Serial number: 6351HSME1E031A03
Subsystem 4 - Serial number: 6361HSME69090F03
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 HW: 1K0 953 549
Component: Lenksäulenmodul 012 0030
Coding: 0000002
VCID: 6FEDB5997E4C9F3926-803A
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 5P0 920 902 E
Component: KOMBIINSTRUMENT VO3 1054
Coding: 0000401
Shop #: WSC 54064 210 66681
VCID: 306F76E5A3F2C0C17F-8064
1 Fault Found:
00003 - Control Module
014 - Defective
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 C HW: 1K0 907 951
Component: Gateway H08 0080
Revision: 08 Serial number: 2600104609071A
Coding: 3D0F0340078203
VCID: 275D9DB9963C8779AE-8072
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO 1054
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN1.lbl
Part No: 1T0 959 701
Component: Tuersteuergeraet 09 0140
Coding: 0000016
VCID: 74E7BAF5176ABCE1DB-8020
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 G
Component: EPS_ZFLS Kl.13 1301
2 Faults Found:
02546 - Steering Limit Stop
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Mileage: 720 km
Temperature: 35.0°C
Voltage: 14.00 V
Voltage: 13.70 V
00778 - Steering Angle Sensor (G85)
000 - -
Freeze Frame:
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 BL
Component: 01 KSG 0301
Coding: 99C000BC09000505485B863000
VCID: 7BF591C93A34F3999A-802E
Subsystem 5 - Part No: 5P0 951 171 C
Component: Innenraumueberw.009 4865
Coding: 00000000
Shop #: WSC 00000
Subsystem 6 - Part No: 1K0 951 605 A
Component: LIN BACKUP HORN H01 1201
Subsystem 7 - Component: NGS n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN1.lbl
Part No: 1T0 959 702
Coding: 0000016
VCID: 75E187F11C10A5E9EC-8020
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 5P2 035 152
Component: Radio BNO 0029
Coding: 0010400
VCID: 67DDDDB956BC47796E-8032
2 Faults Found:
01042 - Control Module; Not Coded
000 - -
00856 - Radio Antenna
011 - Open Circuit
Coding: 0050071
2 Faults Found:
Freeze Frame:
RPM: 1071 /min
Torque: 40.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.48 V
Bin. Bits: 11000100
Temperature: 9.0°C
Bin. Bits: 10110000
Freeze Frame:
RPM: 882 /min
Torque: 46.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.36 V
Bin. Bits: 11000100
Temperature: 9.0°C
Bin. Bits: 10110000
Coding: 0017025
Coding: 00056272
Shop #: WSC 00000
Coding: 0021301
Coding: 0000002
Coding: 0000401
1 Fault Found:
014 - Defective
Coding: 0000016
2 Faults Found:
Freeze Frame:
Mileage: 720 km
Temperature: 35.0°C
Voltage: 14.00 V
Voltage: 13.70 V
000 - -
Freeze Frame:
Coding: 00000000
Shop #: WSC 00000
Coding: 0000016
Coding: 0010400
2 Faults Found:
000 - -
011 - Open Circuit
