starts then cuts out
m.r.davies
God's Property
Jun 13, 2006
608
Cardiff
My mate has a 1.4S leon 51 plate
He just rang and said he has a problem with it
its turning over, starting for 1 second, then just loosing all power and turning off
anyone have any ideas off the top of their head what it might be?
i'm going to try and get vag com on it but was hoping someone might have an idea (immobilzer??)
Deleted member 20376
just a thought plugs or ht leads. not sure it that wud cut out tho it would chug.
has it changed his battery or anything. is the earth ok.
m.r.davies
God's Property
Jun 13, 2006
608
Cardiff
Nothing has been touched on the car,
Battery is fine as it turns over with strength, earth lead is worthing checking i suppose
not sure if anyone else has seen similiar
TheMikeh
167
When it cuts out does it 'stall' or does it power down in the sense that the keys been turned off?
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
My cuz 1.4 ibiza had same issue, stalls on idle, done diagnostic and monitored the cylinders, misfired cylinder 1 & 3. New coil pack fixed that
Big_daddy
Oct 20, 2006
3,930
Brummy
just got over here and the immobilizer symbol on the dash is flashing (pic of car with key)
so i take it we need to recode ?
is this easy?
Its either dealer option or think u need the sku code to do this your self, check the ross tech website, this show how to do it step by step ;)
ovni boy
Same with my Cupra, as a quick fix (not permanent) turn the ignition on to point II (ie not fully round to start the car) and leave the ignition on for 10 minutes, the immobiliser will re-set!!
