standard lcr
andyc58
71
Hi what boost should a standard turbo run at.As ive just fitted a boost gauge and its boosting around 16 psi which aint right lol.
andyc58
71
yes with the vacum hose.Oh right.just think 16 psi was alot for a standard lcr
heatfan8
Insert witty comment here
Dec 2, 2008
368
Berkshire
I have no idea what it should be as standard, and have no idea what might cause it to be high. Have you used the correct diameter tube for the gauge?
dg-1984
254
Glasgow'ish
where did you take the pipe from to the gauge? Dump valve or the FPR?
I used 4mm black silicone tubing but the one supplied should be fine.
The wiring to the gauge is just for the illumination of the needle, the gauge and a memory function to store the colour if its a multi colour display.
