Standard headunit wires
BHP Addict
Back in a SEAT!!
Jan 31, 2006
886
Birmingham
Afternoon all
I'm starting the process of improving my ice in the ibiza
I have my oem stereo on my lap and I'm looking at the wiring behind
2 blocks. 1 brown for speakers and 1 black
The black one has 7 wires in it
Green/red - ignition live(I think)
Brown - earth
Black - battery perm live
Grey - ?
Grey/blue - ?
Green/blue - ?
Black/blue - ?
Can anyone help fill in the blanks please?
lemonslap
In The Know
Mar 14, 2009
320
Kent
Radio systems configuration
“MID” Radio System
A - Aerial cable
B - Connector I (20 pin), connector II (8 pin) and connector III (8 pin).
- Rod aerial with amplifier, fitted on the roof.
- Bass speakers, installed in the rear tray.
- Bass speaker, installed in the lower front part of the door trim.
- Treble speakers, installed in the lower front part of the door trim.
Identification of contacts in multiple connectors I, II, III at the rear of the radio.
Note:
Where there is no indication for contact assignment this means either free or vacant contacts.
Multiple connector I, 20 pin
- Dash panel insert
- External temperature +
- External temperature -
- Autoclima 2
- Autoclima 1
Multiple connector II, 8 pin
- Right rear speaker +
- Right rear speaker -
- Right front speaker +
- Right front speaker -
- Left front speaker +
- Left front speaker -
- Left rear speaker +
- Left rear speaker -
Multiple connector III, 8 pin
- Positive (KL 15)
- External mute
- K Line
- S Contact:
- Battery positive (Terminal 30)
- Lighting (terminal 58b)
- Positive switch (aerial)
- Earth (KL 31)
“HIGH” Radio System
A - Aerial cable
- CD-Changer (optional) installed in the boot.
Note:
- Dash panel insert
- Autoclima 2
- Autoclima 1
- Remote control
- AUX IN (Phone)
- BC LEFT switch
- BC RESET switch
- BC RIGHT switch
- SUBWOOFER
- AUX GND (Phone)
- DATA IN (CD Changer)
- DATA OUT (CD Changer)
- CLOCK (CD Changer)
- Voltage supply +12V (CD Changer)
- Change-over voltage +12V (CD Changer)
- GND (CD)
- Left channel (CD IN)
- Right channel (CD IN)
- Positive (KL 15)
- External mute
- K Line
- S Contact:
- Earth (KL 31)
BHP Addict
Back in a SEAT!!
Jan 31, 2006
886
Birmingham
Thanks mate.
I am half way through my install so just wondered what wires I needed from the original HU.
Good jjob I checked TBH. Found a right wire bodge behind the dash!!!!!!! I have novice's playing with car wiring!!!!
BHP Addict
Back in a SEAT!!
Jan 31, 2006
886
Birmingham
Thanks mate, I have read it a couple of times.
I have done a shed load of audio installs TBH so I'm pretty sure of what I'm doing but I have found a bodge on the standard h/u wiring in the dash and has thown me completly.
Should have it sorted this week tho. Im just trying to build my new H/U into my glove box at the minute.
I am amping comps in the front and 3 ways' in the rear. Along with an Active (amped) sub.
So I should only need the Live, Earth, Ig Live, Remote and can leave the rest in the standard H/U.
kyle'87
Modding Disease
Sep 15, 2008
868
Ruislip
Pictures once done :D
Mar 1, 2009
1,079
Liverpool
Lemonslap, do you know which is the standard unit fitted in the ibiza cupras? Is it the HIGH system?
Im going to be piggybacking the standard wiring for my alpine headunit next week.
Im basically going to be extending the "Multiple connector II" using some spare ISO male & female plugs I have.
Can someone check to see if I have this right:
Red ISO Cable (Switched Power) - PIN 1 (Positive KL15) - Multiple connector III
Yellow ISO Cable (Permanent Power) - PIN 5 (Battery positive, terminal 30) - Multiple connector III
Orange ISO Cable (Illumination) - PIN 6 (Lighting) - Multiple connector III
Blue ISO Cable (remote turn on) - Will connect direct to my amp
Black ISO Cable (Earth) - PIN 8 (KL31) - Multiple connector III.
Thanks!
Jan 8, 2008
528
Portsmouth
Can anyone confirm the colours of the wires??? I need to know the colour of the wire for Live and the Memory wire, tried wiring it up blindly and no joy! Nothing worked, im gonna have another go tomorrow but need to know the colours!!!
Thanks!!
Jan 8, 2008
528
Portsmouth
Got it working in the end, however... the cars wiring didnt match up to the diagram above, my wiring was the other way round, terminal 1 should be permanant live but it was ignition live and terminal 5 that should have been ignt live was permanant live as per multimeter readings! But i wrote down the colours if anyone ever needs them!
roloking1806
177
Surrey and Huddersfield
Sounds like a good setup.. I wan 2 see some pics wen its done! :)
I have got my rear speakers/sub sounding nice, but need money to buy an amp and comps for the front..I should post some pics but it doesn't look too neat hehe
