Standard boost 225??
godber225r
T15 PJG
Sep 6, 2008
893
Whiteley, Hampshire
Done some searching for the past half an hour and found that the LCR 225 has about 14psi standard boost? that right?? But what does it vac at??
I am fitting a PSI boost gauge soon so i need to know the figures so i know everything is good and its fitted right. And too see if my car has any boost/vac leaks!
turbin
u mean idle vacuum?
dg-1984
254
Glasgow'ish
sorry to bring this back up, I have just fitted my boost gauge and looking at the figures seems to be boosting fine just wondering about the vac though.
On idle mine sits roughly 22 and when driving with foot off accelerator will go to 30.
From other peoples replies seems to be off, is there a problem, and could someone explain what the vac actually is, i'm not sure thanks.
i don't get that though, as mine sits at 30 when i lift my foot off the accelerator. Other people are saying theres sits bewtween 20-22. Mine also sits at 30 on idle when autochoke has disappeared. I have just a cheap autogauge from Halfords which i wouldn't expect to be true but looking at this it could potentially be fooked and answer an issue i'm having at the min'
