Standard Airbox Piece missing??? i think
Deleted member 20376
as the title says, i think im missing a piece off my original airbox :shrug:
at the min i dont have a pic but i can explain here goes.... :blink:
from the airbox at the box you have a cold air feed pipe. looks a bit like a banana shape that goes round the side of the battery and is held in place by a bolt.
then i have a gap.
i have a piece thats on the back of the light and a bit that goes to the vent??? should there be a gap.
if you have pics of yours that would help me in sourcing what i need.
i did go to seat and explain they said its a possiblity but wasnt 100% sure :cry:
thanks in advance people. :confused:
lc_allan
Northern Monkey
Sep 15, 2006
3,389
A gap is normal, there is no direct vent from that tube to the bumper or back of headlight :)
I wondered that on mine but it's ok.
cheers guys.
lol well thats what im thinking of doing.
on the diagram that seat had it does look like a peice that clips together tho. they said it would be £30 but he wasnt 100% sure.
D.K
LCR 225
Oct 24, 2007
6,408
se london
cheers guys.
If you want the OE one PM me I might have one in the shed.
LEE69
Stage 2 Revo'd
Dec 10, 2004
21,262
74
C\UK\Devon\Torquay
Not sure there is one is there.
Mine is another one with one missing.
brad1
That last bit doesn't really matter, tbh to make it more efficient get a 3" or 4" cold air feed and put it from airbox to fog light, much better;)
yeah i thought about doing that but before i wasnt sure if it was direct feed as it looks like it should be. bit wierd how they have pretty much designed it to be but then havent finished it off.
D.K
LCR 225
Oct 24, 2007
6,408
se london
The feed pipe only sit's in the bit at the front it does'nt really support it much cos it's boletd in place further up, IYou could have mine but I snaped it getting it out :doh:
Stick a 3" feed pipe in there mate it will get a lot more air into the box ;)
stewbie55
No longer a Newbie
Aug 12, 2006
427
Does anyone know how you remove that 3rd bit (the one Gaz is missing) from the car? I fitted a 3" feed ages ago but couldn't work out how to remove that last piece so I could feed the pipe through. That bit seems really firmly attached somewhere but couldn't work out how to get at it without taking everything to bits :shrug:
think ill do that. cheers pal.
was thinking of getting one of those forge carbon enclosed ones anyway.
Ronin225
4,652
22
Worcester
stewbie, i had the same thing so just left the last bit in but hopefully going to get a FMIC soonish so will have a really good look when all the bumper, etc is off.
