just exchanged my ecu for stg2 ccc....but it dosnt seem to be running right....
the outside temp was 26.5-27 degress (if that woudl effect it that much...)
stage 2 custom code...logs
Here my stg1 logs
http://www.seatcupra.net/forums/showthread.php?t=260836
im seem to be gettin higher air maf reading with no CC corecction also lower intake temps...
any suggestion on what i can do?
reduce the timming,boost?
Code:
Group A: '003 Group B: '020
RPM Mass Flow Load Ign. Timing Idle Stabilization Idle Stabilization Idle Stabilization Idle Stabilization
TIME TIME
MARKER STAMP /min g/s % °BTDC STAMP CF CF CF CF
0.45 2200 40.83 100 6 0.01 3.8 3 1.5 5.3
1.34 2440 56.22 100 0.8 0.84 3.8 2.3 1.5 5.3
2.24 2760 78.08 100 3 1.84 3.8 0.8 1.5 5.3
3.04 3120 91.42 100 3.8 2.64 3 0 0.8 3.8
3.95 3560 104.42 100 6.8 3.45 2.3 0 0 3
4.84 4000 112.67 100 10.5 4.44 0.8 0 0 0.8
5.76 4440 131.42 100 9.8 5.24 0 3 0 0
6.55 4800 137.67 100 7.5 6.15 0 3 3 0
7.35 5160 143.39 100 5.3 6.95 3 3 3 3
8.15 5440 142.58 100 9 7.75 3 3 3 6
8.95 5720 142.89 100 5.3 8.55 3 3 3 6
9.74 5960 145.08 100 9 9.35 3 2.3 3 6
10.54 6200 146.11 99.6 6 10.15 3 2.3 2.3 6
Code:
Group A: '118 Group B: '115
RPM Temperature Load Absolute Pres. RPM Load Absolute Pres. Absolute Pres.
TIME TIME
STAMP /min °C % mbar STAMP /min % mbar mbar
0.4 2280 42 91.4 1210 0.01 2200 65.4 1000 1060
1.4 2600 39 85.9 1770 0.91 2440 99.2 2240 1480
2.3 3040 39 83.5 2260 1.9 2800 137.6 2380 2070
3.1 3440 39 82.4 2300 2.71 3200 154.1 2390 2340
3.91 3840 39 82.7 2210 3.51 3640 151.1 2350 2240
4.91 4320 39 85.5 2190 4.39 4080 151.1 2310 2200
5.71 4680 42 87.8 2180 5.31 4520 153.4 2230 2190
6.51 5000 44 91 2100 6.11 4880 149.6 2130 2150
7.31 5320 45 94.1 2030 6.91 5160 146.6 2090 2070
8.1 5560 47 95.3 2000 7.71 5440 139.1 2100 2020
8.9 5840 48 95.3 1930 8.5 5680 134.6 2100 2000
9.7 6040 49 95.3 1870 9.3 5920 130.1 2040 1900
10.5 6240 50 95.3 1830 10.1 6160 126.3 2010 1860
Here my stg1 logs
