P-Torque stage 2 map, Forge TIP & 007p, open cone filter and standard Seat Sport FMIC.
Just added a full Miltek system so here are the logs.
Not the best weather for logging as it was raining and I was struggling for traction![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Thought?
Code:
Group A: '003 Group B: '020
Idle speed Air mass in Throt Angle Ignit Angle Idle Stabilization Idle Stabilization Idle Stabilization Idle Stabilization
TIME 700-820 rpm 2.0-4.5 g/s 0.2-4.0% 0-12 BTDC TIME
STAMP /min g/s % °BTDC STAMP CF CF CF CF
0.47 2880 75.08 94.5 21 0.01 0 0 0 0
1.37 3240 120.92 100 9.8 0.96 0 0 0 0
2.18 3800 132.92 100 8.3 1.77 0 0 0 0
2.98 4000 122.89 89.4 14.3 2.58 0 0 0 0
3.89 4440 152.5 100 9 3.49 0 1.5 0 0
4.79 4840 160.89 99.6 10.5 4.31 0 1.5 1.5 0
5.59 5200 163.25 100 15 5.19 0 1.5 1.5 1.5
6.61 5560 167.36 100 16.5 6.1 0 0.8 1.5 1.5
7.43 5840 174.06 100 17.3 7.01 0 0 0 0.8
8.32 6120 171.08 100 17.3 7.91 0 0 0 0
9.22 6360 173.22 100 12.8 8.82 0 0 0 0
Code:
0.4 2840 38.56 21.6 25.5 0 0 0 0 0
1.2 3120 106.22 100 12 0.8 0 0 0 0
2.02 3520 126.33 100 6.8 1.62 0 0 0 0
2.82 3960 139.42 100 7.5 2.42 0 0 0 1.5
3.73 4400 149.83 100 14.3 3.22 0 0 0 1.5
4.53 4800 157.5 100 9 4.13 0 1.5 1.5 3
5.44 5160 162.64 99.6 15.8 4.94 0 1.5 1.5 3
6.24 5480 168.69 100 9.8 5.84 0 1.5 1.5 3
7.05 5760 169.61 100 13.5 6.65 0 0 0.8 1.5
7.95 6040 169.19 100 12.8 7.55 0 0 0 1.5
8.77 6240 174.33 100 15 8.35 0 0 0 1.5
9.57 6440 174.33 100 15.8 9.17 0 0 0 0
10.37 6640 175.14 100 17.3 9.97 0 0 0 0
Code:
Group A: '115 Group B: '031
Engine Speed Engine Load Spec. Boost Actual Boost Lambda Factor Lambda Factor Bin. Bits Bin. Bits
TIME 700-6800 RPM 15-150% 990-1800 mbar <=1800 mbar TIME
STAMP /min % mbar mbar STAMP
0.4 3000 85.1 1920 1260 0.01 0.992 1
1.31 3280 85.1 2180 2140 0.91 0.938 1
2.32 3760 85.1 2100 2270 1.82 0.938 0.922
3.23 4160 85.1 2030 2320 2.73 0.883 0.883
4.03 4520 85.5 1990 2280 3.63 0.875 0.875
4.83 4800 86.7 1980 2290 4.43 0.867 0.875
5.74 5120 87.5 1980 2240 5.25 0.867 0.875
6.56 5440 87.5 2060 1990 6.14 0.875 0.875
7.36 5720 87.5 2060 1890 6.94 0.867 0.875
8.25 5960 87.5 2010 1860 7.85 0.875 0.875
9.05 6160 87.5 1940 1850 8.65 0.844 0.836
9.96 6400 87.5 1870 1770 9.47 0.797 0.813
10.77 6600 87.5 1850 1820 10.36 0.821 0.813
165.35 2960 85.1 2240 2070 165.75 0.961 0.938
166.26 3440 85.1 2110 2280 166.66 0.891 0.883
167.06 3880 85.1 2090 2260 167.55 0.867 0.875
167.97 4320 85.1 2020 2210 168.37 0.86 0.875
168.87 4760 86.3 2000 2070 169.28 0.867 0.875
169.7 5040 87.5 1990 2000 170.18 0.867 0.875
170.59 5520 87.5 2060 1950 170.99 0.883 0.875
171.49 5800 87.5 2040 1870 171.98 0.844 0.867
172.4 6000 87.5 2010 1840 172.8 0.836 0.844
Code:
Group A: '118 Group B: '114
Engine Speed Air Temp In Boost Dut Cyc Actual Boost Eng Load Call Corr. Load Engine Load Bypas Dut Cyc/0-100%
TIME 700-6800 RPM <=110 C 0-100% <=1800 mbar TIME <=150% <=150% 15-150%
STAMP /min °C % mbar STAMP % % % %
0.4 3400 26 85.1 2020 0.01 191.7 189.6 137.6 70.2
1.31 3920 25 85.1 2260 0.91 191.7 189.6 179.7 85.1
2.11 4200 24 85.1 2050 1.71 191.7 188.1 145.9 85.1
2.93 4560 25 85.5 2110 2.51 187.2 185.1 176.7 85.1
3.84 4960 26 87.1 2050 3.42 179.7 177.6 172.2 86.3
4.73 5320 27 87.5 1910 4.33 173.7 171.6 163.2 87.5
5.63 5600 28 87.5 1900 5.23 169.2 167.2 154.1 87.5
6.45 5920 29 87.5 1840 6.03 166.9 165.7 150.4 87.5
7.25 6120 30 87.5 1830 6.85 159.4 158.2 148.1 87.5
8.16 6320 31 87.5 1810 7.66 154.9 153.7 148.9 87.5
9.07 6560 32 87.5 1750 8.56 148.9 147.8 139.8 87.5
Thought?
