squeeking coilovers
pg glasgow
119
fitted the fronts fk"s today but im getting lots of squeeking.i sprayed a little of the stuff you get with the kit on but never helped much.any ideas?
pg glasgow
119
my mate and i fitted them him being the mechanic me being the helper.the droplinks are the shorter ones from the fk kit.didnt notice any knocking though
pg glasgow
119
had another drive in it there the squeekings quite loud inside and out the squeek also gets worse under braking
pg glasgow
119
coilovers are now all on back and front.the squeeking was just the metal part behind the brake discs touching the disc it must have bent slightly when we had it off just bent it back a little and problem solved.
loving the way the car looks now. a couple of slight knocking noises though i"ll have a nose around tomorow think it could be a bit of the plastic catching on something.
pg glasgow
119
ill give all the parts another once over to make sure there tight again tomorow. anything else you can think of that could be causing it?
