sps3 lcr
owen lcr
orvil
Oct 10, 2006
1,179
montrose, scotland
hi folks, just got my sps3 today and had a search as to what settings are a good starting point.
what do you guys run on~
low boost~high boost~ timing
i use 98ron fuel at all times so i think the timing should be set at about 6-7
thanks alot, owen
bentaw
Revo'd LCR
Oct 1, 2004
1,067
Hampshire
owen you must have the old sps3 you can actually take it to revo and they will give you a updated one that removes low boost and high boost and replaces it with just boost. For the one you have though try LB9 and Timing 6 that is what i was running mine on when i had that one
bentaw
Revo'd LCR
Oct 1, 2004
1,067
Hampshire
do you have vag com if so then you can log that then start adjusting the settings timing settings be careful with i wouldnt go any higher than 6 on the side mounts especially if you dont have vag com to see if there is any pull back
