Anybody know if the nipples on either side of the valve need to be plugged?
David.
common sense really mate.......think about it carefully now.....
what is it going to leak? electricity?
lol
thats the n112 valve which sits on the rubber bracket underneath your hands in those pics
the open nipple should be blocked but i dont know if this will help you find your lost boost, certainly could be the reason though. just stick a piece of vac hose on the end of it and then block that up with a screw.
btw 7psi is not limp mode...its standard
will removing this stop the boost surging problem that happens from time to time?
