Sport owners - Tyres
PDaddy
213
Hi Guys,
Which tyres are you most happy with on your sport. I'm looking at :
Vredestein ULTRAC 225/40 ZR18 92Y XL Rim-protection
Thing is there are 215/40 R18s on the car at the moment, would the above fit?
aceman
1,078
West Yorkshire
they will probably fir but your speedo will be out due to the wider cross section. General rule of thumb is that you reduce a profile size for an increase in cross sectio hence you would need 225/35 to keep the same rolling radius. I would stick with the same size if I were you as your mpg is likely to fall as well.
PDaddy
213
The 215 is a very rare tyre size though and thus very expensive! car has 4 different tyres on at moment, each at various stages so might not have a choice but to go 225. will the ride be affected much by the 225/ 35 / 18. mainly motorway driving.
PhilOfCas
478
The capital of Yorkshire
morning RallyD, r u sure on the circumference info ?, in't the profile (and therefore circumference) a ratio/% of the width ?, the greater the width, the greater the height for the same profile rating ?
CupraR-Rog
Just Cruising...
Jul 19, 2003
2,291
West Somerset
Phil, you are correct that the aspect ratio is as a %age of the tyre width :)
And to the original question - I say go for it!! Every VAG car I've driven has had very poor speedo accuracy - overreading by much more than other cars I have driven, and so your speedo will probably be more accurate with the larger tyre!! Check with a satnav or other gps device before you make the leap to see how far out your speedo is!
PDaddy
213
Cheers folks, ended up getting the ultracs, very happy with them, very low noise and so far plenty of grip.
