split r
stumccaig85
Hey im needing a bit of help. just fitted my new Splitter valve on my standerd leon and cant seem to get a dump noise off it, im not running it fully atmo though but i thaught it wld still dump? thanks guys.
RickC
BUILT NOT BOUGHT
Dec 23, 2004
1,621
Lincoln
two and a half turns in i think, try unscrewing the top all the way thus having the spring as soft as it can be and see if you get a whoosh, although it wont be loud because you are running standard boost and when you rev it on the drive you are not under load thus not making much pressure to blow off
stumccaig85
Tryed it
i have tryed it totaly unscrewed and only get a kind of purr if that makes sense. lol. will i need a cold air ?
D.K
LCR 225
Oct 24, 2007
6,408
se london
Wot car have you got mate .
If its running low boost you may not hear it, also when you say its on full recirc mode does this mean you've got the blanking plate on and not the trumpet type bit
RickC
BUILT NOT BOUGHT
Dec 23, 2004
1,621
Lincoln
no you wont need a filter, look in the dv down the trumpet part, it should have a small opening, and the recirc bit should have a big opening, it has been known for them to be swapped upon manufacture,
a friend has one on his standard beeza cupra and tbh it sounds like an ant farting.
i suggest you get it remapped to make full effect of the sound.
stumccaig85
Thanks i have the trumpet on and the hole is smaller on the trumpet side. will need the get it remaped i think. just not got enough boost presure. thanks for the help.
satilaboy
375
this is what my spltr sounded like with standard boost
http://www.youtube.com/watch?v=CW5O_vD6KPo
nice! mine sounds loud when in the car with the windows up.(and the radio off/down low(ish)). can't hear it with the windows down but i've not had the chance to have someone drive past me yet to hear what it sounds for an onlooker!
i've got a green panel filter and revo stage 1.
done nearly a full tank in less than 200 miles though! been driving so as to get a nice loud whoosh right enough so that probably explains it.
still loving the noise!
satilaboy
375
ran mine today in full recirc - was surprised to hear that the whoosh was still there - albeit much quieter than normal
RikH
Texas Cowboy
Oct 17, 2005
2,474
Yorkshire
there are no specific settings with the split-r
its adjustable specific to your car, its finding that setting that takes the time on occasion
Deleted member 20376
hmmm, i no it sounds stupid but how do you no when its perfect i only want it to woosh at high pressure.
RikH
Texas Cowboy
Oct 17, 2005
2,474
Yorkshire
trial and error
also depends where you run this valve, i only ever ran mine on standard boost but when i moved it to the TB-IC hose it was noticeably louder, could never hear it when it was on top of the TIP
mine was loud for standard boost compared to others ive heard
caveo
put mine back to full re-circ yesterday as the lag between gears was killing me and to be honest the noise is slightly better ( more of a flutter than a hiss )
mine flutters and hisses flutter sounds cool though
b_wain
118
i have just put on Dynatwist kit and the hiss from my split R has more or less dissapered:(
caveo
will sound fantastic but will suck too much hot air in from aroun the engine, but if you only want sound.
