split hose
james walker
cooling is the key people
May 24, 2007
5,121
retford notts
have checked the linked thread, what size silicone hoses do i need to replace this please, can see howe its done by looking at it?
could this cause a decrease if fuel economy as ive noticed this recently....
james walker
May 24, 2007
5,121
retford notts
you noticed a difference since fitting it.... gonna go down the silicone route, afaik its 19mm silicone hosing and a tpiece to match, looks straight forward enough?
adam cupra 20vt
Built Not Bought.
Mar 31, 2005
6,162
Mud Hut
I'd only had the car 2 days before I noticed it and I had it replaced at the same time as a full service and filter upgrade so I can't really say if it made a difference or not.
As far as I can see it looks fairly straight forward to do from looking at the other thread.
adam cupra 20vt
Built Not Bought.
Mar 31, 2005
6,162
Mud Hut
Do you have any marine fabrication or hydraulic companys locally?
Thats where I used to get mine from......there handy for making up turbo feed pipes to :)
james walker
May 24, 2007
5,121
retford notts
not a bloody clue matey, ill check yell.com......
also anyone know what this will cause... i.e running rich, or lack of pressure etc
Cupra Ross
Breaks things............
May 15, 2005
1,379
Edinburgh, Scotland
One of the bottom ones split on mine. You'll notice a big difference in throttle response when its fixed. If its been like that for a while, your cam cover and intake manifold willl be very dirty.
Cupra Ross
May 15, 2005
1,379
Edinburgh, Scotland
cam cover not filthy, well ive just cleaned it...
theres alot of gunk inside the hose.
was it the same hose that split on yours.
No, it was the right hand breather hose on the underside of the intake manifold, yours is the one on the top right. It would have the same effect on performance though.
adam cupra 20vt
Built Not Bought.
Mar 31, 2005
6,162
Mud Hut
That stuff in the link is fine tho its rated to 6.5bar of pressure :)
I'd rather have a brass T piece, make sure you keep an eye on the plastic one.
I also usually buy my T pieces a mm or 2 bigger than the ID of the pipe :)
james walker
May 24, 2007
5,121
retford notts
sorted the hose yesterday
for future info
i purchased 19mm red silicone piping from the bay
£14 for 1 metre, thats plenty
18-22mm jubilee clips £55p each
19mm t-piece from the bay £2
followed guide in the link above, easy as...
now car pulls better, job done
£55 ofr oem part made of chocolate, £20 quid replacement into silicon
great mod and would recommend users to do this, as the oem hose will break at some point.
cheers
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=300253728012
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=290274810367
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=250340814410
james walker
May 24, 2007
5,121
retford notts
i would, it looks exactly the same as the link on the first post..... exept the hoses are red, and the tpiece blue
bit of a faff getting enough purchase on the lower hose connection, but everthing else ease, and took 20 mins
all i did seperate, was use jubilee clips to connect all hoses to tpiece to make sure they stayed on.
but for 20quid its a real worthwile mod, and makes the bay look prettier
james walker
May 24, 2007
5,121
retford notts
well worth it...
im thinking of uprating other hoses in the bay, considering how pap that oem one was..
whats the reccomendation on these and where from... forge etc.
already got tip from samco done
