Speedo Problem
barrie_d
BAZ 1659
Feb 28, 2005
103
Kilmarnock
Speedo always says 0mph
Its been in the garage, they can't find the problem, changed the sensor over, problem still persists and diagnostics come up clear, anyone on here have any idea wots up?
Oct 17, 2006
2,141
Mid Wales
Is the connection between the needle and the clock itself ok - it could be that the clock's turning but the needle's slipping - just an idea
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
unlikley, when i removed the needles, they are very tight to remove. Have you check on vag.com what speed the car is showing?
dainott2105
mk1 Cupra and mk2 FR TDI
Nov 4, 2006
685
swansea
got the same issue mate, how did you find the broken wire and where was it??
checked my speed using the climate control screen (shows it in kph) and needle is def not loose.
cheers
barrie_d
BAZ 1659
Feb 28, 2005
103
Kilmarnock
Garage fixed it for me, guy said the live feed wire from the sensor to the instrument panel was broken about 3 feet from the sensor
dainott2105
Nov 4, 2006
685
swansea
cheers, dont have any idea of the root the wire takes do you. I wouldnt know where to start in looking for the wire. I have a replacement clocks but dont wanna change them yet if i can sort the wire (much less hassle)
dainott2105
Nov 4, 2006
685
swansea
:lol::D fair play very good fella LMAO, must have some german in you if your into speedos. Bet there is a fresh towel in your bathroom at 5 every morning aswell :D
dainott2105
Nov 4, 2006
685
swansea
not sure if anyone knows where the speedo wire is routed so i can do a little investigation and see if i can find the prob. Everything else on the dials is working eccept the speedo itself. Any info would be great
Cheers all
