speedo not work and fuel gauge !
May 16, 2008
506
southampton
any one had this problem with there car my speedo and fuel gauge playin up basicly the fuel gauge is going to full an empty then full not sure what the problem is an the speedo wont move at all.
but keep driving then all of a sudden its fine till i switch it off.
cupra collins
216
its the speedo sensor that sits on the gear box i broke mine when i took my box out it speedo stoped working and the petrol gauge was all over the place only a few quid from main dealer to get new one
KingStreet
Speedo & Mileage Problem
What's happening? I have the same problem with my Leon 1.4. (As well as Madmarcus, karls cupra and VegasKid) I can't understand how the two problems are linked unless it is a wiring fault. (OMG!) I have tried another speed sender in the gearbox and have pulled out the instument cluster to try a 1.6 unit. Neither cleared the fault and the 1.6 unit added 100,000 miles to the odometer. Even worse; now that I have replaced the original instrument cluster the airbag warning light is on all the time.
I have asked around and not been able to find a compatible instument cluster from breakers. Even if I do there are issues over the immobiliser which are worrying. I don't have VagCom (should I get one?) to find the error codes.
Does anybody else have any advice please?
KingStreet
Should be! I tried a new "sender" (borrowed one from a mate) but it didn't cure the prob. Hence all the mucking about with speedo, leaving it out too long then having to get the immobiliser un-immobilised.
A few months later after all the mucking about and never really getting to the bottom of having a crap garage involved - the cam belt broke. In some ways it was a relief to get rid!
Still miss it in many ways.
Sad end.
