Hi has Any one ever had the speedo and rev counter out of sync with real speed and revs? At 3k on cluster vcds is at 2k at 5k vcds is at 3k etc etc will rev off the clock as so far out of sync
Is there any known fault with seat clusters?
Yes needles are inserted correctly and when doing out put test they function in correct way but when vehicle is running there not close to correct values and get worse in the higher speed/rpm of vehicle
