speed dependent volume
gazR
CUPRA
Apr 25, 2009
418
Derbyshire
turn off on the stereo, not by vagcom
1. Press PTY/PROG until you hear confirmation beep and the word PROGRAM is displayed
2. Select function to adjust using TRACK +> and TRACK -< until you see "SCV xxx" in the display where SCV is the setting for auto volume
3. Press PTY/PROG again
4. Adjust it using TRACK+> and TRACK -< to the setting you want:
SCV OFF
SCV LOW
SCV MID
SCV HIGH
5. Press PTY/PROG again to store it
6. Press PTY/PROG again to exit adjustment mode.
markmeus
Mark Graham
Jun 9, 2007
2,948
11
Banbridge, Northern Ireland
Does the Leon headunit have a prog button - in my old mk 3 Ibiza, holding the prog button in would bring up settings for the speed dependant volume and stuff like that.
Might not be the same in the leon but I though it was worth mentioning.
Edit: Lol - far too slow.
gazR
CUPRA
Apr 25, 2009
418
Derbyshire
thanks to dh00001 for the pic
motty225
Polestar 2
Sep 11, 2008
953
219
Ashby De-La Zouch
SCV OFF
SCV LOW
SCV MID
SCV HIGH
cheers for that mate :)
mjt
365
What are the other settings you can fiddle with on the PROGRAM menu?
mjt
365
and those do what? :p
I've got a whole list for the CC unit, is there something similar for the radio?
markmeus
Mark Graham
Jun 9, 2007
2,948
11
IGN - would control weather or not the radio goes off when you remove the key from the ignition,
ON VOL - is the default volume the unit will return to after being switched off and on
TA VOL - would be the volume of the traffic news
BEOWULF
I am BEOWULF !!!
Mar 18, 2006
1,186
I AM IN FRONT OF YOU
SCV OFF
SCV LOW
SCV MID
SCV HIGH
Thanks mate this came in very handy :clap:
