SPEC Clutches
Dan Cupra R
The Yellow Sub
May 2, 2006
1,514
Reading
I see TTS Roadsport have an attractive offer on these clutches at the moment. Mine is again feeling a bit slack.
Is anyone running one of these clutches yet? What are your thoughts on them? Good bit of kit? Worth getting?:think:
Dan Cupra R
The Yellow Sub
May 2, 2006
1,514
Reading
I run a spec stage 3 with a billet flywheel, its the badgers nadgers.. I wrote a review if you do search...
Just found it now, sounds like a good bit of kit. I think I may have to invest in one of these myself then.
Did you fit it yourself or get a garage to do it? How many hours labour you looking at?
TurboCupra
190
I work at a garage, from driving the car in and out your looking at 3 and half solid hours, the rear mount on the gearbox can be a pain and compared to other Seats, the space in the engine bay is limited, but not a massivly complicated job..
TurboCupra
190
my mate has the 3+ in his Mk2 20vt that runs 330 at the wheels, hes had no slipping yet, the 3 will be more than adequate.. 3+ is slighlty easier to drive with due to it not being a 'paddle' design..
Dan Cupra R
The Yellow Sub
May 2, 2006
1,514
Reading
Sweet, Ill weigh up my options when I buy, thanks for the advice:)
Prebs
662
Norway, Bergen
Could anyone please tell me the part number for the spec 3 clutch and steel flywheel that people use as I found 2 different types for the mk3 1.8t use on their webpage, and Im not sure wich one?
Prebs
Prebs
662
Norway, Bergen
Nick: Thanks for the tip but I live in Norway thou and Ive bin in contackt with a shop thats recently started to mount Spec clutches. Even they dont know wich one to use so I have turn to the "Bibel" (SCN)
Prebs
