Spacers
Jib
496
31
Doncaster, South Yorks
Ive used the search faclility but struggled to find anything.
Im after a pair of 20mm spacers for my valver.
Any idea where the best place is to purchase these apart from ebay. My paypal account is playing up! :cry:
myseatcupra
ibiza fr tdi
May 14, 2007
791
cardiff/penarth
watch the one on ebay they dont aways fit. you may have to measure the spigot lenght. to get the right set. but it is worth getting a set as they do make a difference
Dave_R
Save a Sheep...Buy Brembo
Sep 20, 2004
3,666
South Wales
I got mine striaght from eibach..... but I just had a look on the web site and it's all changed now!?!?
Click here and eibach links to companies they deal with.
I basically wanted to go for these because they feel a lot lighter than the cheaper ones. ;) But you will need to buy the bolts yourself, got mine from Badger 5.
Grayboy
970
Beckenham
Well 15mm are probably better for strength and safety purposes due to the bigger the spacer the more stress put on the bolts, but saying that Mig had 20mm on his and the wheels sat superbly in the arches, it will also depend on wheel size your going for!
It's worth spending money on these as you don't want your wheel coming off mid corner!
jcs356
Cordy owner
Jul 12, 2004
1,161
Englandland
The rubbing depends if you have pre or post facelift car and how much it is lowered. Pre-facelift, the rear arch had a lip hence unless you have it rolled, 15mm is the max you can go for providing you accept occasional rubbing (e.g. 3 passengers in the back).
Post facelift, the arch was rolled so 20mm is possible.
Go for the Eibach ones. A bit more expensive, but at least they fit without all this spigot diameter problems you seem to get with the cheapo eBay ones.
crezz
pedro motorsports
Jun 30, 2007
4,397
Woolacombe
i would say the 20mm spacers are safer. well the ones i have use the original wheel bolts. this is because you bolt the spacer to the hub and then bolt the wheel to the spacer, therefore not needing to use longer bolts. mine were delta mics i think, just had the little lip bored out inside. fits a treat.
