Jimski
Back to the fold!
Nov 3, 2007
1,350
Staffs
How do all!!
Basically had a set of 4 15mm spacers on the leon, which with them being the same PCD i assumed would fit on the beeza.
However i cannot get a flush fit to the rears even with the hub nut cap taken off. Theres literally 2-3mm in it.
Im assuming that its to do with the inner chamfer of the spacer? Can anyone shed any light on this or offer up a make of spacer that would fit?
Might just have to sell my set of 4 and bolts to buy the 2 correct ones i need!
Also, whilst im here, seems someone had a bit of a frantic session on the horn, and the centre S badge of the wheel has been pushed in a little, is it pretty each to get this off and push it back out?
Jimski
Its wierd that your spacers won't go on, as the centre bore is the same :confused: Maybe use the man tool?
Tried that, i think the problem is that the 'collar' of the ibiza hubs is 3-4mm longer, apparently after talking to some specialists, this WAS a common on older spacers, a 5mm shim/spacer is needed.
So iv sold them, will get proper ones!
Jimski
