Sound Deadening Front Doors Ibiza 2004
funboy.ch
83
Switzerland
Hi Folks, going to stick some Focal's 165 KP's in the doors of my Ibiza2004 (three door). Do I need to do some sound deadening. If so, what is the material called and how is it applied?
I will most likely also move the current front speakers to the back. I saw that there is a lot of space in the back, should I fill that up with something? I previously had the Alana SS in the car so the front speakers are actually pretty good.
Thanks folks, funboy
Baz1
216
Leicester
hi funboy
You can add some sound deadening material to the doors and also other panels aswell. There are a load of different materials available, from Dynamat, Brown Bread, Bodyline which all are on a roll that you basiclaly stick to the metal on the doors. There is also something called sludge by Second Skin which is a.. er.... sludge that you paint onto the panels and works just aswell (or better if applied thick). Have a look here..
http://www.caraudiodirect.co.uk/accessories-sound-deadening-c-73_72.html
All sorts of different applications.
This is the one most used nowadays and is very well recommended
http://www.caraudiodirect.co.uk/second-skin-spectrum-sludge-gallon-p-4860.html
The space in the back? What do you wanna fill it with? What ideas do you have? Focals are lovel comps and ideally you need to have the soundstage from the front, so no need for rear speakers at all, apart from a subwoofer or so.
What other equipment do you currently have?
Baz
funboy.ch
83
Switzerland
Hey Baz1, I've a Kenwood KDC-W7534U HU in there. That is it at the moment, still looking for an amp, I am looking at these:
Alpine MRP-F550:
http://www.alpine-europe.com/typo3/index.php?id=mrp-f550&no_cache=1&L=1&tx_comproductcatalog_pi1[show]=features#ridercontent
Blaupunkt VA4100:
http://www.blaupunkt.com/de/7607792110_main.asp
JBL GTO 75.4:
http://caraudiosecurity.com/shop/pro...s_id/2911.html
Crunch GTR 350.4:
http://www.12voltshop.eu/eu/index.ph...oducts_id=9659
Just don't know which one. About the back, well, I was thinking about just sticking the current front speakers in the back and I was thinking because there is so much room behind the back speakers, that I would need to fill it up with some sound deading stuff..?
Also just realized that I will have a problem getting my focals into the front doors :(
http://www.seatcupra.net/forums/showthread.php?t=126797
Any tips are greatly appreciated.
funboy.ch
83
Switzerland
thanks Icecavern, now I just have to find a place that sells it in Switzerland. Is it like a foil to stick onto the sides of the doors, etc? What do you all in the UK pay for the meter squared?
This is what I have found so far, but in Austria and with quite a price tag:
http://cgi.ebay.at/Dynamat-Xtreme-Trunk-Kit-Daemmung-Daemm-Material_W0QQitemZ330116347084QQihZ014QQcategoryZ138856QQtcZphotoQQcmdZViewItem
and this
http://cgi.ebay.at/Dynamat-Xtreme-Door-Kit-Daemmung-Daemm-Material_W0QQitemZ330116347107QQihZ014QQcategoryZ138856QQtcZphotoQQcmdZViewItem
Here's something I could get in Switzerland, think it could work?
http://www.multiplanet.ch/product_info/ANTIDR%D6HN-PLATTE_ZEALUM_ZNBS-2.html
RichieRich
Mk4 Golf GT TDi
Sep 17, 2005
2,367
Oxfordshire :)
www.bebo.com
it would work but may not be as good as dynamat and funboy are you looking for decent quality sound? if so it would be out of the top 2 maybe 3 but not bottom one (for decent sound quality) look more at the RMS power output instad of the max output will be a better way to tell how good the amp really is
funboy.ch
83
Switzerland
hi RichieRich, i'm definitely going for good quality sound and not just loud and lots of bass. I'll either get he Alpine or the Blaupunkt one. Thanks for the info.
I'll have to see what I can do for the sound deadening, would prefer to buy in Switzerland and not have to import from Austria. I'll look around some more.
funboy.ch
83
Switzerland
thanks for the offer RichieRich, but I'm in Switzerland, don't want to do the entire import tax, etc thingy.
BTW, is there a guide or info on what/how to sound-deaden doors, etc? Do I just put the entire sheet on the door or do I put small pieces at different locations?
RichieRich
Mk4 Golf GT TDi
Sep 17, 2005
2,367
Oxfordshire :)
www.bebo.com
either way but the best way is to do the entire door... behind cables (to stop viabrations) etc.. but it costs more of course.. i just put it were it needs it.. behind the speaker and adapter and holding my crossover in place...
