sometimes jerky
p34ch3y
tastefully modified
Oct 17, 2005
2,879
cambs
in the morning my cars a bit jerky only sometimes, even more so when my 007p is reversed,,,,,,,,,,
any idears:blink:
May 2, 2006
2,758
is it when its cold? can get jerky if you dont warm it up properly
wouldnt have thought it would have anything to do with your 007p reversed as the only difference is that it "relies" on the spring, is your spring goosed?
Forbez
Huge Member!
Feb 11, 2004
5,878
S.Wales
Probably as the air will be cooler and denser in the morning, than a warm afternoon, you notice it a little more.
Could also be your body isnt fully awake, and not reacting at optimum speed.
May 2, 2006
2,758
hello again matey
you can check your DV by doing a leak back test
not too sure where the doco to tell you how to do this, otherwise i would post it upbut do a search and it should come up
p34ch3y
tastefully modified
Oct 17, 2005
2,879
cambs
yea ive seen the forge test smithy, it last bout4/5min max mate,,,,
so what may be up with me spring?
acidstrato
My Fast says shut up!
Dec 9, 2004
5,942
Newport, South Wales
springs weaken and the dv ends up opening early
to test it you gotta push the piston up from underneath with a finger, cover the top nipple with another and the let go of the piston and if it comes right down then theres a leak. if it stays up then its fine
dont think this is your problem though, would be boosting incorrectly and sounding whooshy
id just say its cos its stone cold...try letting it warm up longer in the mornings before setting off
May 2, 2006
2,758
because its cold, your oil hasnt warmed up so everything isnt lubed up as well, also your n112 will be blowing in warm air into your airbox until your revvs drop (meant to be cool) your air/fuel mixture will also be wrong until engine is fully warm (automatic choke will be on)
p34ch3y
tastefully modified
Oct 17, 2005
2,879
cambs
[smithy] when you say the n112 blows warm air into the air box where about dose it blow into because i dont have a std air box im runing a ram air
May 2, 2006
2,758
you only need to uprated spring in the forge DV if you are going past 250bhp i have been told by some very respected tuners, if you dont run your car above this, it is pointless getting the uprated spring
