Nov 2, 2004
9,334
South Wales
Revo Stage 2
HB9 T9
+3 degrees
+2% primary fuel tweak
102% Fuel Tweak Increasing Loads
Profec B2
I only logged 002 and 020 on the rollers where it pulled 200whp bang on, operate reckons it was running lean as fook, 15:1 which im blaming on an exhaust like i think, do these logs look like its runnin lean? More logs needed?
Code:
Sunday	12	July	2009	09:28:33
6K0 906 032 AA 		1.8L 20VT EU3    05 0002
	Group A:	'020				Group B:	'002				Group C:	 Not Running
		Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization		RPM	Load	Inj. On Time	Mass Flow
	TIME					TIME					TIME
MARKER	STAMP	 CF	 CF	 CF	 CF	STAMP	 /min	%	 ms	 g/s	STAMP
	6.8	2.3	3	3	4.5	6.4	1360	36.1	4.51	12.28
	7.6	2.3	3	3	4.5	7.2	1480	40.6	4.1	12.03
	8.4	0	0	0	0	8	1560	39.1	4.1	11.94
	9.2	0	0	0	0	8.8	1680	38.3	4.1	12.19
	10	2.3	0	0	0.8	9.6	1600	76.7	8.61	26.58
	10.8	4.5	0	0	3.8	10.41	1640	91	9.43	30.83
	11.6	4.5	0	0	3.8	11.21	1840	101.5	10.25	36.86
	12.4	4.5	3	0	3.8	12	2040	113.5	11.48	46.5
	13.2	3.8	3	0	3	12.8	2240	134.6	14.35	59.78
	13.98	3.8	3	3	3	13.58	2480	174.4	19.68	89.06
	14.78	3	2.3	3	2.3	14.38	2720	191.7	22.96	107.17
	15.58	3	2.3	3	2.3	15.18	2880	191.7	22.96	115.69
	16.4	3	2.3	2.3	2.3	15.98	3040	191.7	22.96	127.36
	17.18	3	2.3	2.3	2.3	16.78	3240	191.7	23.37	138.36
	18	2.3	1.5	2.3	1.5	17.58	3400	191.7	23.37	135.17
	18.78	0.8	1.5	2.3	0.8	18.38	3600	191.7	22.96	139.03
	19.59	0	1.5	0.8	0	19.19	3760	191.7	22.55	141.94
	20.38	0	1.5	0	0	19.98	3920	191.7	22.14	148.5
	21.18	0	0.8	0	0	20.79	4120	191.7	22.14	153.67
	21.99	0	0	0	0	21.59	4320	191.7	22.14	159.5
	22.79	0	0	0	0	22.4	4480	191.7	21.73	162.92
	23.59	0	0	0	0	23.19	4640	189.5	21.73	168.78
	24.39	0	3	0	3	23.98	4800	189.5	23.78	174.53
	25.19	3	3	3	3	24.79	5000	188.7	22.55	180.64
	25.98	3	3	3	3	25.59	5120	184.2	21.32	183.53
	26.79	3	3	3	3	26.39	5280	180.5	21.73	181.67
	27.59	3	3	3	3	27.19	5440	174.4	20.91	179.42
	28.4	0	3	3	2.3	27.99	5560	168.4	20.5	179.17
Run was the third one, but didnt log boost, but this was the run before which was stopped short as the operator didnt like seeing the 15:1 afr...
Code:
'118
RPM	Temperature	Load	Absolute Pres.
 /min	°C	%	 mbar
1520	36	100	1140
1720	36	100	1320
1960	36	100	1510
2320	36	100	1870
2640	38	84.3	2530
2880	39	81.6	2540
3120	39	78.8	2540
3440	41	76.9	2540
3720	43	73.7	2500
4000	45	69	2450
4240	45	62.4	2420
Now i looked at block 032, and the readings were -0.2% and -16.4%, which means the ecu is pulling back fuelling?
Only faults on the car is a duff front right ABS sensor and soft code for the missing EVAP system, i guess this wouldnt affect running.
Now i just been out and logged a little after seeing the 032 figures, so i put the cat back to standard as in the fuelling on Lemmiwinks back to 100% and 0% and now my 032 block is -0.2% and -8.6%.
And here some logs, 3rd gear sorry.
Code:
Friday	17	July	2009	21:51:50
6K0 906 032 AA 		1.8L 20VT EU3    02 0002
	Group A:	'114				Group B:	'115				Group C:
		Load	Load	Load	Load		RPM	Load	Absolute Pres.	Absolute Pres.
	TIME					TIME					TIME
MARKER	STAMP	%	%	%	%	STAMP	 /min	%	 mbar	 mbar	STAMP
	5.2	143.6	135.8	59.4	0	4.8	1800	58.6	980	1090
	6	157.1	149.3	88	100	5.6	1880	78.9	1050	1130
	6.8	168.4	159.7	106.8	100	6.4	2000	97.7	2070	1290
	7.6	175.2	167.2	136.8	100	7.2	2200	118	2120	1530
	8.4	182.7	173.1	179.7	85.1	8.01	2520	156.4	2190	1950
	9.2	187.2	177.6	191.7	82.4	8.8	2920	191.7	2220	2480
	10	190.2	180.6	191.7	81.2	9.6	3400	191.7	2220	2540
	10.8	190.2	180.6	191.7	78.8	10.4	3880	191.7	2220	2530
	11.6	190.2	180.6	188.7	76.5	11.2	4320	191.7	2190	2380
	12.4	189.5	179.1	182.7	74.5	12	4800	185	2160	2210
	13.2	183.5	173.1	173.7	72.9	12.8	5080	178.9	2130	2130
	14	176.7	167.2	163.2	71.8	13.6	5440	167.7	2080	2090
	14.8	172.2	162.7	157.9	72.2	14.4	5680	160.2	2020	1990
	15.6	167.7	158.2	153.4	80	15.2	5920	155.6	2000	1930
	16.4	165.4	155.2	150.4	92.2	16	6080	151.9	1970	1890
	17.2	163.2	153.7	147.4	89.8	16.8	6200	148.1	1940	1850
	18	161.7	150.7	145.1	90.2	17.6	6400	145.9	1910	1840
	18.8	161.7	150.7	50.4	0	18.4	6480	142.9	1890	1820
Code:
	Group A:	'002				Group B:	'020
		RPM	Load	Inj. On Time	Mass Flow		Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization
	TIME					TIME
MARKER	STAMP	 /min	%	 ms	 g/s	STAMP	 CF	 CF	 CF	 CF
	16	1920	77.4	9.84	31.36	16.4	0	0	0	0.8
	16.8	2040	98.5	12.3	41.08	17.2	0	0	0	0.8
	17.6	2280	123.3	14.76	58.03	18	3	3	0	0.8
	18.4	2600	165.4	21.32	91.25	18.8	3	3	0	0.8
	19.2	3040	191.7	24.19	126.39	19.6	3	3	0	0
	20	3480	191.7	24.6	142.08	20.4	3	2.3	0	0
	20.8	3960	191.7	25.01	153.11	21.2	2.3	2.3	0	0
	21.6	4400	191	22.96	159.08	22	2.3	2.3	0	0
	22.4	4760	182.7	22.14	165.61	22.8	2.3	2.3	0	0
	23.2	5160	178.9	21.73	176.39	23.6	2.3	2.3	0	3
	24	5480	166.9	20.5	171.25	24.4	1.5	1.5	0	3
	24.79	5720	160.9	19.68	175.53	25.19	0.8	0.8	0	3
	25.59	5920	155.6	19.27	176.75	25.99	0	0.8	0	3
	26.39	6080	152.6	18.86	177.19	26.79	0	0.8	0	2.3
	27.19	6240	149.6	18.45	178.86	27.59	0	0.8	0	1.5
	27.99	6360	147.4	18.04	177.64	28.39	0	0.8	0	0
Any comments would be great. :D
The lean issue could be due to the boost controller boosting a little early ahead of the map since the n75 is no longer in control. I would increase the (fuel tweak increasing loads to 105%). Any chance you could get a wide band probe installed.
If anything the boost is coming on later than requested (115) so im not sure thats the issue.
I would add fuel but without a wideband i cant be sure to what is exactly is happening, plus my long term fuel trims are showing that its reducing fuel.
Wheres Dave when you need him? lol.
The problem is though Phil, most of the time we drive our cars off drive off boost or light load so the fuel trims could well be showing good fueling but mods done to the car may mean that we go lean under load.
The boost log looks like a lean condition can occur between 3000-4800 rpm.
Guess what. Pump was the problem. :)
Changed it to a 4bar last week and went to the dyno yesterday... :):):)
Result, not far off perfect AFR, maybe a little lean on initial load but otherwise thats a lot better than the 15:1 under full load before.
