soild yellow oil light
logan2769
hi all first post on here for me so hello to you all .i have just picked up a 110 se tdi toledo when you turn on the ignition and it does all its self tests the yellow oil light comes on no flashing and a beep and stays on,
is this a oil level switch problem or is it the bonnet reset thing?or is this something else?does anyone have any pictures or manual ref to the where abouts of these sensors?
techie
Skoda Techie
Mar 22, 2003
5,438
Worcs
If the level is ok then I would think there may be an issue with the bonne catch switch not resetting the light.
Fault code check should tell you if there is a problem with the sensor itself.
logan2769
also the engine sounds a bit cammie or it might just be the general engine nosie,are these engines quite noisy in general? ,i know its over due a service
logan2769
Does anyone out there have a picture of the bonnet oil level reset thing or a picture of the oil level sensor its self
