sodding locks
leeattie
hi all, new to this site, my ibiza is just a standard 1.4 fresca model,
as i am selling to upgrade to a cupra i need to fix my doorlocks,
i have the new handle (drivers side) and i have the piddly bits, the paddle spring, etc etc
can anyone give me information on how you fit the bloody things please??????? or a diagram they could post up or a link to a website showing me, i dont want to buy the haynes manual as this is the only problem and i am absolutely skint so couldnt even afford £10 - £15 to buy one if i wanted to lol.....
please help ive tried the other forums and got nothing back this is my last hope someone be kind please haha.
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
ensure the key goes in the barrel and all the brass bits are present and correct and smooth on the outside
put barrel into handle (grease it a bit)
hold barrel in tightly
on inside of handle place spring and cap over the end (loop) thats sticking out
hold paddle in hand and use 2 fingers to push spring back exposing the loop on the barrel
hook in paddle
make sure all is ok and test left and right :)
if you are removing you old lock barrel DONT pull the key out unless you like puzzles and have patience and logic
leeattie
"if you are removing you old lock barrel DONT pull the key out unless you like puzzles and have patience and logic"
i will be removing the old lock barrel mate, any tricks to it?
so when removing the current lock barrell you do it with the key in it yeah? and ya dont remove the key untill its all spanky doodle and up and running?
thanks for your help by the way...appreciate it big time!
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
yeah for sure as you cant get it out otherwise :) and when its out LEAVE THE KEY in too
sounds daft but if the paddle is damaged and still there you simply unhook it to get it out
there is 2 types early and late - these may help?
leeattie
had it all apart today and had no luck with it what so ever!!! when the barrel slides in the handle the end you see is flush/flat so doesnt look as though anything would connect to it what so ever! do i need a newer lock barrel you reckon?
how much would it cost me to take it to a SEAT garage, or can you get fobs fitted to make it function??? really need this sorting out a.s.a.p lol
