so do these actualy work then???????????????????
marshyc
299
Huddersfield
:no:
I wouldn't mate. They are basically a resistor which goes between two connections on your MAF/Air Intake Sensor. The second of your links shows a variable resistor/potentiometer.
I can only assume that this would in time do damage to your engine. It tells the engine that the air is colder than it is so you get better power no doubt but the way it does it to me spells trouble.
If I were you I would avoid. :blink:
TBCupraT
Limp Mode Squad ™
Well I have seen the light no more revo or jabba for me
Super Resistor all the way...... [B)]
Check out my RR Graph.
The dip is where I turned the resistor to MAX-POWER Mode.
