Snowflake on dashboard...
December
239
Cluj-Napoca, North Romania
Ok i bought my car in the summer.. and winter just started with really low temperatures... now.. when i started my car the other day there were -4.5 degrees Celsius.. and a little snowflake apeared on the dashboard ( not the AC )
It was going on and off for a few seconds.. then it stopped and remained ON.
Now... Whats the deal with that ? is there something wrong ? What should i do ?
gazjones
its to warn you there may be ice forming at thoses low temperatures!
no joke!
December
239
Ok, i read those threads... now... will my AC work after the engine temperature rises ? Will the snowflake dissapear after i drive my far around for a while ?
What can i do to get some heat in my car ? :p
Deleted member 7659
You sure the manual isn't hiding in a light grey wallet in the slot under the steering column? They're not terribly obvious if they're pushed well in....
gazjones
yes the heater will work just when its so cold the air con dosent need to work basically wont cool the air anymore! heat will still come through
