You mean small when it pops up?
It's because we had customised templates on the VB3, but on the new server we took original vb files rather than modded ones.
I'll see if I can work out what it used to pop up to
Yeah, you remember I moaned about it before? When you use the advanced edit, then click "more" at the bottom of the smilie list - the popup window needs to be wider/bigger.
If I remember, there's an X and Y variables in the page (probably in the advance edit window), but I can't remember what he said he set them to last time...
okey doke :)
I'll leave it be then! hoped it'd be in some skanky javascript that is clear, so i'll leave it!
