skweaking dashboard
zoltar
does anyone experience skweaks and rattles coming from alhambra dashboard? mine has only done 22000miles but already making annoying noises as if it was 220000[:@]
any idea on the general area of the squeeks? a few owners have reported them around the sides of the dash where it meets the A a posts! the removable panel at either end of the dash move and rub against the main body of the dash and A post trim! a quick squirt of a silicon lube has been known to help! that or a couple more clicks on the radios volume button :happy:
zoltar
thank you, what you`ve just described sounds about right, any idea how to remove that panel?
julian2002
i had mine in to be 'fettled' and it came back with a new squeak / rattle. upon further investigation it turned out the transparent cover had come off the fuse panel and was making a racket. popping it back on correctly cured it. just a thought before you go dismantling stuff.
