Simple question regarding aftermarket head unit
Motty
Hi,
Installed an aftermarket head unit in the Leon, radio reception not great. Have just purchased an Aerial connector with a 12v feed to boost the signal. What colour wire do I connect this to on the car's loom? The 12v feed is blue in colour.
Cheers,
Alan.
Motty
Thanks,
Just thought someone might know off hand as I don't have a tester.
matylad
279
Crewe, Cheshire
Motty, i used the remote cable to power mine, generally this is a blue cable and is part of the loom that comes with your headunit. Your headnit instruction book should tell you exactly which wire this is. This is also the wire that controls power to an amplifier (switches it on/off with the ignition) Worked for me anyway.
Hope that helps?
Matt.
RobM
Back from the dead...
Sep 27, 2006
4,982
Southampton
Blue cable or blue and white cable will be fine. As Matt says, your instruction manual will say which wire is for an external aerial or remote turn on.
Skorchio
600 Miles to a tank :)
Jan 23, 2007
1,570
Nr Milton Keynes
Hope that helps?
Matt.
You should not power anythink through your remote lead.. This is not designed to take load.. Only to switch relays in amps to they turn on!!!!!!
dmmsta
Sold car - bought bike
Feb 10, 2007
787
Maidstone - Kent
If it's an aftermarket (Alpine / Sony / etc) then you should have a Blue or Blue/White wire going to position 5 in the ISO plug from the HU.
You should be able to connect to this...
All the adapter needs is a switched 12v +ive feed, and your new HU should have one of these as part of the loom.
The extra Blue wire from the HU is technically for the switched remote wire for aftermarket Amp installation.
Thats all said assuming your adapter came with the block connector pin on it...(my one from Halfords did)
