Silca bag split
Jun 27, 2024
The silva bag has split in my coolant. The only advice I can find is to remove the bag itself to prevent this. What is the best way to completely flush the system? Every video I’ve watched seems to be a partial flush.
Appreciate any advice
BillyCool
704
275
Leicestershire, UK
Generally you cannot fully flush the system without special VAG tools/diagnostics due to various one way valves etc.
My DIY fix was to drop the main (bottom) radiator hose and get as much out as possible. It was actually done at the same time as a cam belt/water pump change so worked out well. That was 4 years ago and so far so good.
You could drop the hose, fill up, drive a bit and repeat. It's not that scientific though. Do you drive a TDI? The blocked heater matrix is a well discussed topic.
Reactions: SuperV8
