side light problem
dimond
anyone had a problem with there side lights when i turn mine on the headlightcomes on dim but when i turn the headlights on it goes normal ive looked at all fuses etc.. can anyone help??
killer205
206
if its what i think it is then its ment to do that as it has a dim circut built into it
GTV
Veggie powered TDi's
Feb 16, 2008
479
Cambridgeshire
yes there is a big yelow resistor in the offside wing to do this, you can just unplug it if you don't want it to do it. Some mk2's do this and others don't ie our Ibiza does but the Vario doesn't have it fitted.
dimond
cheers mate worked a treat
crossedmike
Ive noticed mine is intermittant then with i cleaned connectors worked but now break light is same and keeps getting me pulled
