When I first bought my Ibiza back in September I couldn't help but think the side lights were more or less a waste of time.
Despite the usual horrible orangey/yellowey glow from conventional bulbs I found the illumination to be pretty dim and poor.
I reckon this lack of illumination is mainly down to the lack of reflection.
Noticed where the side light bulbs protrude into the main headlight reflector i.e situated close to the main or dipped beam bulbs greater reflection is present. Sadly not so with the Ibiza.
So first I purchased one of these http://www.autobulbsdirect.co.uk/50...60-Degree-5-LED-bulbs.html?bulb_search=c22039
Looks quite nice, but the light given off is less so than the conventional 501 bulb! Waste of money and expensive, avoid!
Secondly these http://www.ultraleds.co.uk/501-194-t10-anti-bulb-warning-xenon-white-wide-angle-13-leds.html
Much better than the overly expensive ones listed above. The illumnation was definately better than the conventional bulbs, despite not sliding all the way in (they were too long). At 195 lumens they were rather bright, good value for money I thought
. However, three months later I noticed they seemed be dimming. When extracted from the headlight cluster much to my dismay the dimming had been caused by the L E D's falling off!!
I suspect this was down to heat, either poor componentary was used or simply the heat built up to an excessive point due to the design of the cluster.
So the other day I bought a pair of these http://www.ebay.co.uk/itm/350604461211?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Fitted today and these are the results
[img=http://imageshack.us/scaled/thumb/585/dscn1376l.jpg]
[img=http://imageshack.us/scaled/thumb/842/dscn1380a.jpg]
I'm very pleased with them, they're like minature cree torches!! Ok the beam isn't a full 360 degrees but as you can see from the photo of the garage doors it's certainly acceptable. The construction of the bulbs is good as is the fitment. No problems connecting them up or sliding them into the sidelight tunnels, also the light given off is a lovely clean white. Does help to angle them though as the beam can be directed due to the nature of the cree bulb.
These have to be the best side light bulbs I've come across yet, they certainly solve the dim conventional bulb problem above and beyond. For 15 quid delivered I'm very happy, I'd highly recommend.
