Should I have remote windows
Phil K
Here's your sign
Oct 18, 2004
548
Surrey darling...
AFAIK it's meant to be a feature on the LCR but my remote doesn't do the windows :confused:
SO, should I have it but it's dissabled on VAG-com or did they take it off the late ones (mines a 55 plate) ?
Also, do the foldy mirrors work from the remote too?
Sorry if it's been asked before - I did a search but couldn't find a direct answer :doh:
Pabs
5,936
Basingstoke
exactly as richy says above. The only functions on the remote fob are the lock and unlock functions. i think pressing the lock button twice disables the deadlock, but thats about it.
timbland181
Yeah thats what it says in the manual. I have it with me today (odd i know)
The remote key can only be used to lock/unlock the door(s)
Hold the key in the locking position for a second or so and the windows wind up - holding the key in the open position apparently opens them. Although i havent tried it.
Phil K
Here's your sign
Oct 18, 2004
548
Surrey darling...
Cool, cheers for the info guys... I would have checked my owner manual if Wiltshire and Sons had given me one for the right car - idiots!
I'm suprised that it doesn't have this feature from the remote tbh as all my previous VW's have been able to do it - B5.5 and a B6 Passat plus a mk5 Golf and lastly a Octy VRS! My Corrado only does it from the key but that can be forgiven as it's 11 years old...
Oh well can't say I ever really used it much anyway - it's just a nice touch :)
Going to have to go back to Farnham Seat again at the weekend as they forgot to stamp my service book and I need the right manual... hopefully I won't have anymore stupid questions before then :lol:
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
yeh jus checked mines, it has! cool feature, bad thing is only works using the key in locks, not via remote control, turn the key either way to open or close the windows - all 4 windows
Big_daddy
Oct 20, 2006
3,930
Brummy
hwo do you activate this feature using vag.com so i could use the remote control it self? what tab do i click on to do this?
gtd86
Doctor of driving
Sep 9, 2006
159
www.batit.com
no you can't use vag com but you can use another program, can't remember what its called but u'll need a serial vag com lead, and to boot comp into dos, the program is similar to vagcom though....i'll find the link in 5 mins
gtd86
Doctor of driving
Sep 9, 2006
159
www.batit.com
is it tiwn K line because i tried mine but i think its only a single line n i cudn't get it to work...2 secs just trying to get laptop started up(got the links on it).
slick
Bit of an animal
Mar 15, 2005
1,124
Essex
Auto Window units can do what you want there.
I have one, the windows and mirrors fold in and up when locking the car, and the mirrors unfold when i unlock the car, if i press the unlock twice, the mirrors and windows roll down all of them.
Handy little thing, total closure so to speak!
Big_daddy
Oct 20, 2006
3,930
Brummy
well gtd86 has software that will convert existing remote to control your windows. works cheaper, mines mirrors fold in as well, the software may allow me to control the mirrors too.
jus waitin for him to post me the link
gtd86
Doctor of driving
Sep 9, 2006
159
www.batit.com
Hi, right sorry got called down to work just while i was plugging the laptop in...
http://www.passatworld.com/forums/showthread.php?t=219402
that thread has the info you need for programming the convenience module, looks quite easy...
Not tried it my self as my vagcom cable is only single k line.
But half way down the page you need to down load this:
http://129.125.253.199/vw/diversen/VDC_PRO_CD-Image.zip
And burn that to disk, its a image file which contains a bootable cd with dos and the vag program, just type vag.bat when it loads up and it will run the program.
then just follow the instructions...
But mind you'll need to check your conveniece model number...
Big_daddy
Oct 20, 2006
3,930
Brummy
thanks for that, turns out my laptop dosnt have serial port so i cant check it, may end up buying that litle gadget that programs everyt thing for you.
is there another software that runs in windows and supports usb?
