Shortning Brake pedal Travel
Gm8
Jun 13, 2007
661
Glasgow
have you checked all the slider pins are in good nick and not seized ? when i first picked up my beeza , 3 out of 4 calipers had this prob , and i had to push the pedal right to the floor to get any kinda braking
WeeJase
pert
Jun 2, 2001
8,595
what hoses you have?going to braided hoses does help a bit,but i think it is inherent of VAG cars,urban myth thats its just the RHD ones too
jcs356
Cordy owner
Jul 12, 2004
1,161
Englandland
Unfortunately this is a common problem for people with brakes with a larger piston capacity than standard. The master cylinder on the car as standard is designed to shift a certain volume of brake fluid for a given level of pedal 'press'. You've now got a larger piston in the brake, so for a given press of the pedal, the same amount of fluid moves, but as the piston is larger, the brake doesn't move as far.
In the S3/TT/Mk4 world, this is a common problem with people who put massive Porsche calipers on their car expecting a huge increase in braking. Yes, you will get better braking, but perhaps not as good as you would have expected because of this problem. Keeping the master cylinder and the brake piston volume in the correct proportions minimises this, which is why the Brembo's off the LCR are such a popular upgrade for this platform. Not only do they offer improved braking, but they also better match the standard master cylinder than more exotic stuff on the market.
As Mark says, you need to source and fit a master cylinder which is better matched to the calipers you are using.
kiearn
156
Norwich
Just had to do mine three times and despite pulling quite a bit out of each nipple and stopping everytime there was no air in the waste pipe it was still lose.
when i went and did them again there was still air in them but after third time the peddle was really tight.
gregclarks
Trying to Resist ARBs
May 31, 2006
314
definately need a bigger master as JCS mentioned, i heard a notion that an uprated servo may also ease the problem; i am just throwing it out there, 'i know nooothing!'
