Short Shifter
beattie17
1,353
Perth
I was goina fit that but decided against it and went for neuspeed short shift, same as TT but with shorter throw, works a treat.
ttothec
349
Reading
someone has definately fitted one... u need to get a "lift reverse" gearknob tho
i think they look like a good piece of kit... much cheaper now than they used to be too!
guess it depends if u want to keep a standard gearknob
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
The miss`s is getting me one for my birthday (2 weeks) so ill let you know how i get on with it.
I just emailed the seller asking if its a push down or lift up reverse once installed. I think some of them you are able to keep the OEM knob.
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
This is the response i got,
Hi
Not actually sure but would assume it will work as normal (push down) no reason to think otherwise.
U-zera
Think im just gunna wait until i have it to see what knob to get.
ttothec
349
Reading
i found a set of fitting instructions on line a while ago and im pretty sure u have to use a lift reverse knob... il have a quick look now
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
I`d like to keep the OEM knob to as some of those aftermarket seat sport knobs are pretty tasty. expensive, but tasty ;)
pj1985
1.8T Power
Oct 31, 2006
2,218
Hampshire/Surrey
Hasnt PhilW got this? He will know if it can be push down reverse or point us in the direction of which his kit is if its push down reverse. His is an ebay B&M copy I believe.
Martin M
www.midnightmotors.net
Nov 12, 2006
1,322
Kent
I think i might just get the Neuspeed one as i know it works well and is relatively easy to fit.
The only problem with the ebay one is i'm guessing you'll have to take off the exhaust and drop the selector out to fit it.
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
Yeh the exhaust has to come down along with the heatshield which apprently can be a pain.
pj1985
1.8T Power
Oct 31, 2006
2,218
Hampshire/Surrey
