Short Shift
Mckellar
You can get them for the golf gti (mk3) i know that because my friend has one, and i believe they share the same box.
There was one on ebay not long ago, went for around £60 second hand. iirc ofcourse.
Czechboy
Tarmac terrorist
Apr 14, 2005
1,607
Hampshire
If you are on a budget, get your hacksaw out (or an angle grinder if your a real man) and chop down the stick by 4cm. Thats what I did in all 3 of my past cars and it did the trick ;)
Mckellar
any side effects Mig?
After doing that, u then replace the gearnob with a golf one ;) performance + styling that costs about £10 all in.
chris27
169
Sounds like a plan lol. And as i cant be bothered to go outside because its dark, cold and wet - hows the gear knob attatch? Is it screwed on or does it have little screws to pinch it on??
Boi Ninja
16 valves of sweet shhhhh
Dec 23, 2005
863
Enfield, Shanktown
and chris27
hmm, think i might give it a go too actually and if it doesnt work its an excuse to buy a b&m lol.
as above, hows it attach though? can i use the original knob with it cut down :whistle: i like it, it says cupra on it and looks nice .
Czechboy
Tarmac terrorist
Apr 14, 2005
1,607
Hampshire
I'm affraid you can't use the original knob. Maybe if you used some PVC glue then it might work but I've always had a nice sparco/momo knob to fit and they use grub screws so they fit fine.
No side effects either and as a bonus you can actually use the cig lighter socket while driving, without the gearshift banging into it everytime you go to put it into 3rd gear.
Mckellar
to take the gearknob off, unhook the leather gaitor, and keep on twisting anti-clockwise and after u realise, like me that you've already ran out of thread, just pull it off, dead simple.
I ended up twisting for ages thinking it had been stuck on a thread, oops!
Mckellar
i can now charge my phone and use my sat nav easier thinking of it that way :clap:
Pedro
If you really want to you could try using a die to recut the thread on the cut down stalk - you'd probably want to chamfer the top off first though to help it cut in :)
F2 Stu
I. Am. Legend.
Oct 4, 2001
5,577
Crawley, UK
Worth noting that the B&M is for 02A cable change g'box on a 2.0 16v
To fit it 'properly' you have to drop the exhuast and heatsheild to drop the shifter box from the tunnel.
their is a way of changing it without doing all the above but its not for the faint hearted:)
