Sorry I missed this posting, yes, if you are talking about what you have found after lifting up a corner of the plastic strip below the windscreen, you need to remove a plastic rivet on each side before lifting that plastic strip up a bit. So, yes, on top of the strut all you will see is a black plastic cover, it is just covering the top of the strut with a "peg" fitting down into the hex end of the piston, just pull that up and off.
Originally I attempted to remove the long black plastic rain water cover from that area, but after taking the wiper arms off I could not get it to move, so I looked into just lifting the corners up to get access to the top of the struts - and that worked.
These struts have 2 nuts on them, the lower nut keeps it all together, the top nut is just used to fix that assembly to the body of the car.
Despite what you think, when reassembling these struts, fit the top mounting before fitting the lower nut, it will look like the top mounting is not really being held in place very well, but it is being held well enough and it will get trapped in place by the top nut after the strut is fitted back onto the car.
I think that you seem to be able to take access to workshop documents, but I just used a Haynes repair manual for a VW 6R Polo which is identical in these areas and more!
