Since owning the car it's had a bit of a
problem this is my weekend car so not been driven much,
When cold it seems to be crunch in 1st,2nd, until warm then the gearing is fine,
Would this be down to the clutch itself or something else?
Also I'm wanting to change the inlet to a right side exit so I can fit a k04 charge pipe, what would be the easiest way to lengthen the throttle body wires?
Just cut then extend?
