I've been in contact with Seat to get some clarity on servicing for my Leon FR ST184....this is what they said....
"The only difference between fixed and flexible servicing is the oil change element. On flexible the oil change service interval is up to 18,400 miles or every two years (flexible), and on fixed the oil change service is every 10000 miles or 12 months
The inspection service is carried after two years / max. 20,000 miles and then every year or 20,000 miles after that irrespective as to whether the vehicle is on fixed or flexible.
The additional service items are provided below:
Air Filter - Replace Every six years or 60,000 miles
Brake Fluid - Replace after three, five or seven years.
Diesel Fuel Filter - Replace Every 40,000 miles.
DSG Oil and Filter - Replace at 40,000 miles.
Pollen Filter - Replace every two years or 40,000 miles.
Timing Belt - 140,000 miles or every five years."
This sort of stuff should be in the user manual or service booklet, but no. Hope this is useful.
I've also asked what additional tasks are carried out during an Inspection service, over and above a traditional (every 10k / yearly service). No reply to that one just yet.
EDIT....additional detail from Seat today.
"Oil change service
Interval: Minimum every 10,000 miles or 12 months, whichever is the sooner.
Maximum, every 18,000 miles or two years
Check brake lining thickness
Engine oil and filter change
Reset service interval display
Service
sticker
Basic inspection service
Interval: First 18,000 miles or two years, then every 18,000 miles or 12 months thereafter.
Check front & rear lighting
Check windscreen
Check brake system
Check brake fluid level
Check battery condition
Check breakdown set
Inspect tyre condition
Service
sticker
Supplementary inspection work (over basic inspection)
Interval: First 36,000 miles or three years. Every 36,000 miles or two years thereafter.
Check underbody protection
Check headlights
Check front and rear axle
Check V-ribbed belt
Check/lubricate sunroof
Check exhaust system
Corrosion check
Cooling system check
Oil level check
Interior lighting check
Check windscreen wash/wipe
Check engine compartment "
