Service parts - what is needed?
dynebaruk
Hi guys (and gals)
Trying to sort out how much I need to set aside for when I invest in a mk3 cupra. I want to make sure I give out a really good service as soon as I get it to make sure nothing goes wrong with it. So far I've got:
Timing belt kit
Spark plugs
Fuel filter
Oil filter + Oil
Water pump (metal propellor)
Coolant
Air filter (might aswell go for a proper panel filter)
New wiper blades (will get Aero wipers)
Drive/ fan belt
I was also looking at getting an oil pump too as I believe they are driven off the timing belt? Euro parts do one for £77 which is quite a bit of money. Is it worth doing?
Anything else I should get done?
daves ibiza
yes mate id recommend a oil pump and while your there clean srainer as they do block and cause a hole lot of problems yes all in list is correct:p
daves ibiza
sucks oil through a srainer its like a sive up to the top give the lubrication lol
dynebaruk
Oh right, is this inside the engine then? How much are they?
daves ibiza
its just a pipe that goes in the sump off oil pump just clean it thats all id recomend a oil pump depending on miles on car:D
