The car has been serviced by me. As I dont want seat charging me ££££££££ for a simple oil and filter change. If its anything like the VW's I normally work on there will be a sequence to follow to re-set the service indicator,does anybody know this sequence?
If not the bloody thing can blink untill the owner gets rid.
ignition off, hold the odometer reset down then turn ignition on and continue holding, then it will flash up oil and then reset, then you can let go. need to hold about 15secs roughly.
