service due at 44.000
pillgrim1
53
hi everyone
just looking for some information regarding what should be done on this service
Air filter done @ 34.000
cambelt done @34.000 trying to find out from dealer if water pump was included but very much doubt it
looking to change
Spark plugs
Brake fluid ?
Fuel filter
Clutch oil/filter ?
As anyone any suggestions on additional items or is that everything covered
The car is 05 leon fr 150 no mods
any info would be appreciated
Bit of a novice with diesels :confused:
godber225r
T15 PJG
Sep 6, 2008
893
Whiteley, Hampshire
They will have on record if the water pump was done aswell. they recommend that the water pump is done with the cambelt so i would say that it has been done. The 40,000 mile service is the big one
Do what you mentioned above plus change the
GEARBOX OIL
POLLEN FILTER
OIL AND FILTER
You wont need to change spark plugs as your FR 150 is a diesel and they dont have them.
pillgrim1
53
thanks godber
plenty to get on with there
would have spent ages looking for those pesky plugs:whistle: proper novice
will def ask dealer
cheers
godber225r
T15 PJG
Sep 6, 2008
893
Whiteley, Hampshire
Changing the brake/clutch fluid is a real test of character!!! good luck, you will know what i mean!!!
Give yourself a good day to do all that work, and its allot easier if you have 4 axle stands.
