Did this summary a while ago. I think you've covered everything except the bonnet lock, which is not in the schedule but something that gets reported as a
problem on here often enough that prevention is much better than cure
Oil change service every 10K
- change oil and filter
- check brake pads and disks
Full service every 20K or 12 months, whichever comes first
- change pollen filter
+ check lights, tyres, wipers, "fan belt", toothed belt, steering, driveshaft gaiters
+ levels in gearbox, coolant, hydraulic fluid, power steering, 4wd, screenwasher
Vehicle exterior
- Door retaining straps: grease and lubricate locking pins
- Sun roof: clean and lubricate guides
Not in service schedule but worth doing - lubricate bonnet lock.
Additional items
every 40K,
- change spark plugs (petrol engines)
- change air filter
- change fuel filter (diesel engines)
every 40K or two years
4WD cars, Haldex clutch
every 2 years
- change hydraulic fluid
every 60K or 5 years
- change toothed belt (diesel engines)
every 120K
- change toothed belt (petrol engines) (This may have been revised down recently)
Is there anything else that the collected readership of SCN thinks should be done regularly but isn't in the service schedules?
