Seat Part Numbers??
Hybrid
82
Newport (S.Wales)
Ive got two fault codes could some one please tell me what needs replacing and what the part numbers are for the fault codes.
16500 P0116 035
Engine Coolant Temperature Circuit
Range/Performance
Sporadic
17511 P1103 035
Bank1-probe1, heating circuit
output too low
sporadic
Cheers:cry:
cupra_matt
Audi Technician
Dec 15, 2004
1,362
Carlisle
Coolant temp sender needs to be replaced, this is a common fault.
And probably the lambda probe before the cat, this is also quite common, could be wiring fault but i doubt it.
SpareMan
354
AQX or AYP engine code? If either then:
Temp sender is 059 919 501 A @ £26.29 inc. VAT
Lambda probe (front of cat) 06A 906 265 N @ £97.64 inc. VAT
SpareMan
354
Part numbers as above, Skoda will definately be able to supply the temp sender, not sure if the lambda probe fits any Skodas
