My daily comute is just 4.5 miles each way which is roughly 1 mile at 30, 1 mile at 40 then 2 miles which are supposed to be 60 but tend to be crawling at 10-20. Although, the 30 and 40 tend to be crawling too.
Had car now since end oct and no warning light.
i think ive once or twice had the regernation take place as ive noticed the smoke/steam from under the bonet when stationary and the 1000rpm idle.
All that commuting being said, every month, i have at least a 3 hour journey in top gear with the revs about 2200-2500 so that should keep me clean.
As a systems designer, i do feel that the DPF is a poor/underengineered system.
There is no harm in designing something which needs to "regenerate" itsself, however its a shoddy compramise when you need to rely on the some chance external happenings to aid this process.
By chance happening, i mean, that you are in a position to drive in such a way that the exhaust gas temperature is high enough to regenerate the DPF.
Even just sitting stationary and holding a high number of rev's isnt going to give a high temperature.
- 3000rpm, for example, by just holding the rev's there when stationaly will not use much fuel, and so not produce much heat.
- holding the same rev's going down a steep hill in a high gear where you need to accelerator will produce very cool gasses, under 100c as your just moving ambient air.
This is why the manual disctates a minimum speed and rpm. The rpm provides the air flow rate for the DPF and the speed (which requires power and fuel) provides the exhaust gas temperatre required.
The DPF should produce its own heat from the oxidation of the unburnt fuel thats injected just after combustion is complete, and it does, but its efforts will be hampered by low exhuast gas temperature.
A quick burst wont do much in the long term. Its not likle blowing dust out a filter with an air hose, the regeneration of the DPF is actually the carbon particles being burnt, much like coal dust being burnt. It takes time to burn off the soot.
This is all why i think they are a poor design. The
problem is that the manufacturers have to include this but need to keep the cost down, so its minimaly sized and employes a crude and unreliable management technique.
Stuart
